jvandyke
Okay, so I'm in the middle of positive to negative ground conversion, removed heater box, battery and plastic tray. There's some rust through holes where tray meets firewall and some little ones in that general area. I'm not too upset about that but I'd like to clean up and "contain" as best I can.
Plan is to sand it down as much as possible, treat it with "something", prime and bomb the area with the similar flatish black someone did the engine bay in way back when. I want to avoid the "might as well" slippery slope.
I've used some Naval Jelly type rust converter/encapsulator stuff in the past, is that still a good idea?
I scraped off some material that looked like fiber mesh stuff, was that original? Doubt it.
Should I put something (besides the plastic tray that I'll re-use for the battery) over the holes? Like "glue" down a piece of, I don't know, plastic or something, just to cover the holes?
The area is actually in pretty good shape, structurally sound, so this is just a stop gap approach for a driver. Someday, good Lord willing, I'll teach myself to weld and I can fix such things properly.
