Battery Terminal Question
T
Tinster
I am installing my new battery this morning.
875 amps, I think.
My positive terminal quickly gets covered in a
nasty brown goo that eats metal.
Is there something I should do to the positive
terminal before I tighten it down?
I always cover both terminals with red wheel
brearing grease but that only works on the negative
terminal.
I know- a trivial thing but the brown goo eats up
everything in proximity.
thanks,
dale
Andrew Mace
<span style="color: #663333"><span style="font-weight: bold">BROWN</span></span> goo? Overcharging from the alternator? I tend to use Vaseline or other petroleum jelly for battery terminals, but whether that's better than wheel bearing grease I can't say....
angelfj1
Dale: two suggestions - 1st - I agree with Andy about coating the terminals AFTER they are in place and properly tightened. You can use vaseline or I am sure the local auto store (Western Auto?) sells their own brand. I have even seen mechanics use grease. The point here is to provide a barrier to the atmosphere which in your case is loaded with water.
2nd - the brown goo must be the result of chemical action with something at that terminal. Try starting over, clean the terminals of the new battery and the top of the battery with a mild solvent. Use a fine wire brush and brighten up both terminals. Do the same for the terminals on your pos. and neg. battery cables. Attach cables and tighten - don't over do it. While your at it check the connection at the starting solenoid and starter. Now smear your favorite protectant on both battery terminals. Good luck
fja
2wrench
Baking soda and water to clean is good start point, IMHO. Do not get
solution into battery cells! Sort of paste-like makes for slightly
better control. Cha-ching....two cents, please.
R
RonMacPherson
Okay, they've given you good advice on making sure the battery terminals and the connecting cables are scraped clean. Then your auto parts store should have little battery saver pads, green and red felt washers soaked with a battery acid neutralizer. Buy them and put them on under the terminals. Make sure the terminals are opened as much as possible before reinstalling them so that you can push them all the way down on the battery terminal Tighten, smear vaseline or other light grease completely around and on all exposed metal on both terminals....
Good to go!
Tomster
Dale I will second Ron's (and all others) comments.
I feel that the felts work
DO NOT get any baking soda into the cells as it will neutrallize the acid. Works well for cleaning up the cables and battery box as well.
Are you getting any of the goo in the braided wire portions that you can see between the end of the red and black insulating plastic and lead terminals of the cables themselves? This needs to be neutralized and coated as well. Easy way to coat is with (GM lubriplate) aeresol canned white lithium grease. Great for hinges etc. as well
T
Tinster
I was not aware of the felts. Are
they a readily available item?
thanks all-
BTW: WOW!! What a difference the new battery makes
at start-up !!
d
TR3driver
Great Pumpkin - R.I.P
Should be. Any place that sells batteries should have them.
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
Tinkerman Battery Terminal Helmets Triumph 13
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
