Sopwith_Camel
ok my xj x300 drains its batter in hours how do i fine the leak??
steve
steve
Which model xj do you have sopwith, I have the xf and that also needs battery to open the boot, but there is still a key lock also up under the chrome trim. probably need to stand on your head to see ityes all my MGs have that. but the issue with the XJ is that the battery is in the trunk and the key has a chip that needs electricity
ok finaly going to try this, dose it have to be the postive lead? do i need the key ON ?Remove the positive lead from the battery.
Place a multimeter set on ohms between the positive lead and the earth lead.
Then you can start checking things to see what is pulling the battery down.
Pull fuses one at a time, if the resistance changes dramatically then you will know which circuit the drain is on.
Disconnect the alternator, i have known them to drain a battery in a very short space of time,
In an ideal world the ohms reading should be as close to zero as possible, but on a modern car there will always be something
drawing from the battery.
