Battery cut off switch
Arch 93
Does anyone know of a shop that repairs battery cut off switches? In this case, one for a 55 100-4. I checked with Nisonger, but as most of you probably know, they only repair gauges. I'd rather not buy a new one because I want to keep the car as original as possible.
Thanks
Its very simple to open and clean and gently bend the spring to get better contact. I did mine two years ago and its been fine and I use it all the time.
Dave Russell
Yoda - R.I.P
Good luck,
Check this reference;
https://www.team.net/html_arc/healeys/200405/msg00172.html
I don't know of any commercial shop that would touch it.
You can get the switch apart. Removing the C clip on the bottom releases the handle. Removing the grommets around the mounting holes lets the rest of it come apart. The fixed & movable contacts may or may not be reusable. The really weak part of the design is the small spiral wound compression spring that keeps the contacts & detents in contact. This spring anneals from contact heating & becomes springless. If you can find a good replacement spring you "may" have success. Make very good notes about how the insides are indexed when you take it apart. I guess it is worth a try. I think that some things are better not left original if reliability is important.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
I think you were lucky. Springs don't lose their spring unless they are damaged. I'll bet that you are still not getting full designed contact pressure. But if it works, what can I say? I may be wrong.
A
Arch 93
Thanks to both you and Dave for responding to my question. Not being mechanically inclined, I have a history of taking things apart with the intention of fixing it, only to find that I can't even get it back togeather again, let alone fix it. Since I have two of these switches I'll try taking one apart and fix it. (Why not?). I suspect that eventually history will repeat itself and I'll end up buying a new switch. Thanks again for your help.
elgatto
Dave,
You might remember me telling you that I have owned my 1956 BN 2 for 23 years and from day one, I have had difficulty spinning the starter. I just read your response to "Battery Cut Off Switch," (the article that you referenced in your response) and I am wondering if the switch might be the culprit? That is about the only thing that I have not checked, other than taking it out and cleaning it up. I had the starter rebuilt, checked the cables, ubgraded the ground to the switch and grounded the engine to the frame with heavier cables and replaced many batteries. Now using one 12 volt Interstate which seems to have slightly improved the starting problem. It seems worse when the weather is hot and when I have driven the car a good distance. When I shut it off and try to start it after it sits for a time, the starter spins very slowly. I had the charging system checked over the years - no problems detected etc. Ideas??
Dave Russell
Yoda - R.I.P
T,
I was able to resurrect the spiral compression spring by stretching it, heating & tempering in oil, & drawing it to a bluish color. If you can find metal grommets to fit the outer case holes, they will hold the case together. I found it quicker to turn hollow rivets out of brass, anneal them, & press in. The switch functions, but I don't trust it still, & am going switchless.
Have fun,
bradal
Thomas: You can always wire around the switch by connecting the battery terminal directly to a chassis ground. Then, whenever you have your switch repaired, place the switch back in the circuit. AL Bradley
Keoke
HI ELgatto, Do not know if your switch is good or bad . simple test: take it out of the circuit and see if there is any improvement.If not try this ,get some thermal insulation and wrap the starter in it and see if that cures the problem. However, I am not aware of a heat soak problem with the Healey cars.-FWIW---Keoke Additional things to try: If the eng-to- chassis gnd strap is not connected directly to the starter make that change.
Keoke
HI Dave, /ubbthreads/images/graemlins/yesnod.gif its really a snap to dismantle the cut off switch and refurbish it. However, if I was all thumbs I think I woukd just buy a new one and forget it ever failed. /ubbthreads/images/graemlins/tongue.gif
Dave Russell
Yoda - R.I.P
[ QUOTE ]
Dave,
[/ QUOTE ]
As I said, "the switch" is frequently the cause of strange electrical problems.The simplest check would be to put the cable lug which is presently on the switch B (battery) terminal on the same terminal as the E (earth) cable lug. This will bypass the switch. Or if the battery earth cable is long enough, remove it from the switch & attach it directly to the frame.
You didn't ask, but the battery cables should be no less than 2 gage copper cable.
If this doesn't cure the problem there is a chance that the starter or solenoid has problems.
If you are profficient with voltmeters, you can measure the voltage from battery earth terminal to frame while cranking the engine. There should be no more than 2/10 th (0.2) volt reading. If it is higher, there is too much resistance in the switch or cable connections.
Similarly, attach a volt meter between the battery hot terminal & the starter main terminal. While cranking, there should be no more than .8 volts drop. If there is more, there is too much resistance in the battery main cable, it's connections, or the soleniod contacts.
Obviously you need a low range volt meter for this.
Dave Russell
Yoda - R.I.P
[ QUOTE ]
HI Dave, /ubbthreads/images/graemlins/yesnod.gif its really a snap to dismantle the cut off switch and refurbish it. /ubbthreads/images/graemlins/tongue.gif
[/ QUOTE ]
Yeah - I know. Just plan on doing it every year or so.
Keoke
/ubbthreads/images/graemlins/nonono.gif Nah Did mine ten years ago no further problems---Keoke /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif
Boink Battery cut-off switch options... or??? Spridgets 10
D battery cut off switch Austin Healey 29
Tinkerman Battery cut-off switch installation Triumph 22
vping T-Series Adding a battery cut off switch. MG 16
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
