TR2/3/3A Battery CCA/CA and Group Size TR3A
M_Pied_Lourd
Hi guys,
Did a quick search but couldn't find what I was looking for. Looking for recommendations for Cold Cranking Amps/Cranking Amps and Battery Group Size for a 1960 TR3A.
Cheers,
M. Pied Lourd
This link shows a G24L or G27L. I would assume that means group 24 and 27. Maybe the "L" indicates where the pos & neg posts are. Both will fit, the G27L being physically larger, but it will fit in the TR3 box. CCA is listed, but I don't know how that compares to original specs, as they didn't use CCA back then. The batteries were rated at Ampere-hour capacity.
I went for the gusto and plopped in an Optima Red Top with 800 CCA. :smile:
In 2003 on the way to TRA in Auburn Indiana, I picked up my third "LUCAS" battery from the Antique Battery Co in Hudson Ohio. I had pre-arranged that it be full of acid and fully charged. All 3 were Group 27 batteries where I specified that the tar top should be their newer polyvinyl something and that the lead cell connectors be visible. Also I wanted the positive post to be at the rear right hand side as you look at the battery - for positive ground.
I got 5 years from each of the first two batteries and am now in my 7th year with this latest one. My records indicate that I have driven 32,000 miles on this latest battery and it always starts in the first millisecond as I push the starter button.
Amp-hours compares more to RC (reserve capacity) in modern terms than CCA. CCA (Cold Crank Amps) is really only relevant at very cold temperatures, and I would guess that most people don't really care any more if their TR3 will start at 0F.
Original spec was 57 AH (meaning the battery would deliver 2.85 amps for 20 hours without going below 10.8 volts), which roughly compares to 80 minutes RC. Since modern batteries have lower internal resistance for the same capacity, I don't think you could go far wrong picking something with at least 80 minutes RC.
I'm running the cheapest top post battery that Wally Mart had, since it never really gets cold out here. But if I were going to drive in winter again, especially with the puny original generator, I would want the highest RC (and CCA) I could find that would physically fit in the box.
I cannot remember if this thing will be a warm season only car. If it is as Randall says, not important.
I went with this in my Wedge. Not a lot
B2618
18lbs/8.2kg
1164 Pulse Cranking Amps
26 Amp/Hr Reserve
8.1” x 3.5” x 6.3"
Right Side Positive
MSRP $208.00
Thanks guys...battery is not for me (I am pretty far from that stage although I wish that I was closer). It is for a fellow TR3 owner who emailed me.
Cheers,
David
No worries, Don't matter who it is. We're here to help
