I have come to the point in my restoration that it is time to try to get oil pressure before starting for the first time. Upon turning the key after disconnecting the coil and removing spark plugs I only got a click from the solenoid. My starter switch was wired as it was prior to taking everything apart and is shown below. The solenoid is also shown as wired below. When turning the key to the second position (not full start) I get power at terminal #2 and 3 on the starter switch and no power other than the direct from battery on the solenoid. I am committed to try to learn how to use a test light and multimeter but not real good at it now. I will not be able to work on the car after a few more days for a while so I thought I would ask if these items seem to be wired correctly and them go from there. Is there a way to test if the solenoid is good? It is the one that was on the car and the car was running. I cleaned it up but was wondering could I have reversed the battery/starter sides and does it matter if I did? Bruce
