AUSMHLY
64BJ8 II. Good day all.
I've attached a photo showing that my two
Drain pipes from the Banjo vent on the top of the carburetors are about 3" long.
Moss's part# 451-250 says "cut to fit" They are 31" long.
Moss's part come straight and is made of copper.
Mine does not seem to be made of copper and is pre-bent.
Should I have concerns that mine are but 3" long and will dip right over the headers?
My friend Randy, another BCF member, has what seems to be hard black plastic tubes attached to his. His looks exactly like mine. Same light grey metal tube, pre-curved and about 3"long. His black extensions run down, then through the 1" hole in the front of the metal heat shield. That hole also has a rubber grommet around it.
What is the purpose of the drain pipe?
Is mine ok being as short as it is and OK to leave as is?
Finding a hard tube such as Randy's will be acceptable?
If so, what and where would I get such a tube.
I was also advised to buy another copper extension tube and use a compression fitting.
Or I could simply get Moss's part and try to figure out how to bend it in that nice shape that mine currently is, without kinking it.
What's your advise?
Roger
What's your advise?
Roger
Hi Guest!
