From every circuit I have found, the ballast resistor is inline of the primary coil. So, from what we know, We have +12 -> -^^^-(3 ohms) -> XFMR -> ... -> Spark -> GND. All we know is that 12 Volts needs to be dropped from + to GND, that is simple. So, why would it ever make sense to drop voltage before you get to your transformer? Dropping from 12 to 6 volts for ignition would mean that the transformer goes from 40,000 to 20,000 volts (the amounts of turns on the transformer are constant and assume 12 -> 40,000 V XFMR you can assume the Ns/Np (Turns secondary/turns primary) is 40,000/12 = 3333.33_. So changing to 6volts would mean V/6=3333.33_ and therefore the output would be 20,000 volts.
This is non-ideal because, as we know, the whole point of increasing the voltage is so that it is EASIER to cause a spark across the spark plug (the higher potential requires less resistance in the air to cross a gap), so why I ask would you want to make it harder to cause a spark on ignition? What the ballast resistor does is reduces that amount of current through the circuit...
So why do people see the voltage go from 12 to 6 volts you ask? The 6 volts is likely the voltmeters trying to go from 12 to 0 but not being quick enough. When the points are open there is no ground and therefore no potential. Since the starter is the only thing turning the car, the distributor is moving much slower, when the car starts, the points change so fast that it always appears to be 12 volts.
For further reading:
https://en.wikipedia.org/wiki/Ballast_resistor
https://en.wikipedia.org/wiki/Transformer <- An ignition coil is nothing more than a transformer.
BlueMax said:
Lucas Sport coils produce 40,000 volts, if you grab hold of a bad wire you will most assured have a bad day, no pace makers please!
Actually, the 40,000 volts is less dangerous. Yes, because of the high voltage the 40,000 volts can spark to things at a greater distance (how spark plugs work), but with simple transformer math you will find that the input of 12 volts and no more than 4 amps input, you will find that the output is about .0012 Amps or 1.2 mA. It takes about 65 mA across an organ to affect it to the point it becomes health critical.
