Tinkerman
I know there is a thread out there on this subject because I started it, but I can't find it. I just want to mentioned what I have done, the conclusions I have come to and If any of you feel that I might be correct.
Talked to a couple of automotive machine shops and one of the fellows told me about the method of spinning the fan on a rod and if it is out of balance the heavy blade would drop to the bottom. You then put the weight on the opposite blade and it should level out. Makes sense to me.
I found a shaft that is slightly smaller than the fan, slicked it up with slickum and tried it out. Did it quite a number of times and it was a total random blade at the bottom everytime. All things being equal I would have to come to the conclusion that the assembly is in balance, right? Or am I leaving something out?
Your sage advise, thoughts and insites would be deeply appreciated.
Thanks, Tinkerman
Thanks, Tinkerman
