chuckmcb
Baffled by ignition light...Any Suggestions??
Charging system on My '66 AH BJ8 has me baffled..Following start-up, the Ignition light is barely flickering at 800 rpm (which is OK), goes off at about 1200rpm (again, about as expected) but then as the rpm goes up the light comes back on and gets brighter as the rpm rises (not good!). As a result the battery is not charging as it should.
So my first guesses are maybe new generator brushes are needed, the voltage regulator has gone bad, or a ground is loose.
However, Before yanking and buying a new regulator or other parts (some that I probably don't need) I'd sure appreciate members ideas on trouble-shooting tests to preform, and what to suspect is causing the problem. Thanks to all.
Chuck McB
Chuck McB
