Hi guys - I've had running issues with the TR8 that I traced to a fuel delivery problem. So I replaced the in-tank pump, which isn't too bad but not something you'd do for fun either. Turns out that wasn't it.
So I rebuilt the suspect carb, and just to make sure i had fuel flow I ran the pump into a clean plastic bag, mainly the catch the flow. Glad it was a clear bag - look what came out of the pump.
At initial pumping;
At the bottom of the tank;
I drained the tank to a point where the pump isn't able to get any more fuel.
The fuel is still a bit shaken up from going through the pump but what the heck is with that?
Ideas?
At initial pumping;
Ideas?
