Back to work, need some bolt info
69sprite
OK, finally got a few minutes last Saturday to work on my '69 MKIV and finish the engine-Rivergate work.
Had to replace the oil pressure high pressure hose, as the original one was done for. As normal, original hose is no longer produced and the one that I got from Moss was much smaller and not reinforced, like the original braided one. Original clamps didn't work (too large). I was told by a local Brit repair shop that they have found that zip ties work as good as clamps for this line. Anyone want to offer their opinion here? I used zips, but can always replace.
Found that in the 8 month layoff, since the last time I got to work on the car, I had misplaced, lost, tossed, etc. some parts I needed. I have paid the penalty for this and ordered what I think I need from Moss, but they don't show the 4 bolts that hold the radiator into the shroud. Can someone give me the specs for these bolts? They have to be really stubby things, so they don't screw up the radiator (my assumption).
Hopefully will be able to use a couple of days of vacation next week and get the engine fired up and running, after about 1.5 years...
Larry Swofford
HAN9-U-83236
Will post a couple of pictures as soon as I figure out how...
Hello Larry,
zip ties and high pressure oil lines don't go together in my view. 0il lines get hot and plastic doesn't like heat, certainly long term.
You might find what you need at an engineering supplier, especially one taht deals in hydraulics.
Alec
Bolts for the rad support, 1/4" 24. That line I think you are talking about goes over nippled ends. Use small clamps that screw tight like your rad hoses.
Use stainless bolts, washers, and lockwashers. Looks so nice. 1/4" X 24 (sae fine) of course. Just put my radiator back on yesterday.
Thanks... I appreciate the input... Called Moss on the clamps to see why their catalog shows both hose and clamps as one...but no real answer... guess I will try to go find two small fuel line clamps when I go try and find the bolts today.
Check those sizes guys, I just parted out a 69 and the short bolts on TOP of the radiator (cross flow) were 5/16 x 24 by about 1/2" long.
The side bolts into the rad uprights are 1/4 x 28
The little screws on the sheetmetal pan are 10/32
