I just took my interior out again, along with the center saddle and radio.
I'm determined to get that pinch bolt on the OD operating shaft to quit slipping. I've machined the clamp just a bit to allow more room for the crimping to work, but I do have a question.
What's causing it to slip in the first place? There appears to have been just shy of 1/16th of an inch to crimp before this exercise, and the OD was working for about 3 weeks. Is a lock washer needed? Is vibration causing the loosening?
I must say, after it slips I don't detect the bolt being loose at all, so it's a bit of a mystery.
Also, I see a slight leak at the operating valve plug on top of the OD. Can I ignore that or do I need to chase that down next? A new plug won't be cheap.
thx
thx
