Well after last weeks little confidence crisis, I am back to making progress.
The bulkhead is all cleaned up. I need to take care of to spots on the windshield frame, on the left it looks like there was an antenna, and on the right something mucked up the frame.
What I am going to do is paint the bottom area which is hidden by the motor, and put the bulkhead back into place. In any case, the bulkhead has to be put on first since everything else is aligned to it.
Then I will clean up the other body parts as I put them in place.
I also spent quite a while bending one of the frame siderails back into its correct location. Looks like the car was hit on the drivers side at some point. This basically explains why the bonnet was not centered, and one side was higher than the other.
