Morris
Drove to work today and everything went well.
Weather was beautiful. 65 and partly cloudy.
Car ran beautifully, but it looks like I am going to have to re-map the spark advance for low revs and high map. Getting a little knock if I give her the gas when I am one gear too high.
Oil pressure is about 70 psi high and 15 psi at 800 rpm hot. That's a roughly 6 psi gain at the low end. Not perfect but workable.
All I did was tighten the head bolts ($0), rebuild the oil pump ($21), and replaced one main bearing ($21). Apparently, SOMEONE put the cap on backwards while measuring the clearance /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
