I recently had my rear end gone through by my transmission/gear specialist. While I trust that he is knowledgable I want to verify that his suggestion is good. He returned the rear end with the axles loose so that when I install the brakes I can tighten up the seals with the drum/lug nuts. He put new O rings in but did not supply me with the paper gaskets and suggested that I add a very slight amount of sealant around (outboard) of the O ring. I purchased some RTV that says it is for differentials/gear oil resistant. Is it enough just to put the sealant or should I but the paper gaskets from Moss? If the paper gaskets are required, do you use them plain or with the RTV? This is for a late model 3000 rear end and everything is very clean. Thanks for your advice/experience.
Hi Guest!
