I wanted to clarify before I ordered some stuff. The MGA Guru says if you are using a MGB banjo axle (I am) you must change the brake line(s). Not much detail given after that. So in the Moss catalog it looks like only the Left hand side line is different in some way. Can someone confirm that that is the only difference? 1962 MK2. I am going to use the MGB wheel cylinder. Thanks Bruce
