I removed the axel shaft on my BJ7 in order to extract a broken bolt (the bolt that holds the axel flange against the hub)and to replace the paper gasket between the hub and flange. The large "o" ring and the "bearing spacer" appear to be in the proper locations, but when the axel is reinserted into the differential, the axel bottoms out before the flange comes flush with the hub. The gap is suspiciously about the same as the thickness of the "bearing spacer", but I cannot figure out how else it would go back together. Is there a particular indexing that I have missed, or could I have re-assembled the spacer in the wrong location? Help!
