TR2/3/3A Auxillary dash switch pictures?
karls59tr
Bronze
Does anyone have pictures of auxillary switches that they added to their dashboard that look similar to the originals or that look period correct. Who sells them?
Geo Hahn
TR3driver
Great Pumpkin - R.I.P
Or you could sand down an original knob and paint it black. I didn't bother, so my radiator fan override switch says "panel" on the knob (but the white paint has fallen off so the word is almost invisible).
TR3driver
Use the vent pull knob on an original or repro switch. No marking on the vent knob.
True, but it's huge! I wouldn't want that great big thing sticking out of my dash.
martx-5
I used the Lucas PS7 as shown by Geo. I'm pretty sure that I got it from ebay. Even though I have a thermo switch for the fan, I use that as an override if need be. I used the bezel from an old TR switch.
PeterK
I bought a vintage old Jag A/C switch panel for a few $ from ebay and refinished it to use as my seat heater control and cooling fan override. Wrinkle finish is new.
Tropical TR
I got a Lucas push-pull switch for a reversing lamp, to be mounted on a period BMC single switch bracket. The bracket is similar to the dual version shown in the second photo, which is a Lucas/BMC configuration for auxiliary lighting.
6TTR3A
There are 2 pre-drilled holes on your dash- one for overdrive and 1 for a heater. If you don't have one or the other
of those accessorizes, you can use those holes in lieu of an extra bracket. The Lucas push-pull switch, similar to
your wiper switch, is quite often on eBay.
Moss, TRF and NOS Locaters sell an aftermarket version which is quite similar to the Lucas ones, but the bezel is incorrect. It's
chrome but has a period look if you're not fussy. As Randall says, sand down an extra knob that you might have, but better yet,
fill in the letters w/JB Weld, body putty or whatever you have. Then sand it & paint it.
TR3driver
Note that the factory would have left the unused holes covered by vinyl. The DPO of my current TR3 (or his mechanic) evidently didn't know that, and drilled a new hole right between the two others. Not really a problem, until I added overdrive ...
Tropical TR
Yes, similar to what I had before adding overdrive. The washer pump was located in the OD switch hole. But having a heater and moving the pump to that location between the glove box and instruments (for some reason there was too large a hole lurking behind the vinyl there...maybe there was a lighter), don't want any extra holes in the dash.
TomMull
Thanks, Randall. You just saved me from doing the same thing. My add-on overdrive switch is under the dash and I've just ordered the correct replacement and planned to move it to the correct position.
Tom
Tom
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
T TR2/3/3A Adding an auxillary fuse box to TR3 Triumph 5
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
tahoe healey Auxillary lights Austin Healey 15
H auxillary rear view mirrors Austin Healey 4
K Rockershaft Auxillary Oil Feed..Is it necessary ? Triumph 23
J TR 4 Auxillary Fuse Box Triumph 4
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
