Autovip car roller for working on chassis-how good
beaulieu
I would be concerned about fluids leaking. Like gas, oil, brake, and clutch. Other then that looks kinda cool.
yeah I was wondering how the transmission seals and rear axle seals would work since they would normally not get oil "under pressure" from gravity /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
But really I will only use it on restoration projects
when I get a car on it I will take some pictures and note the leaks !
Beaulieu
beaulieu said:
or if you have instructions you could scan for me...
Thanks Beaulieu
Did you see the instructions on the website you listed?
yes I saw those, but mine is an older model, not as fancy
just the curved tubes with the mounts for the brake drums ,
I am just not sure how you connect the front one to the back one ,
and if you need to also connect it under the car ?
I am not sure if I got all the parts since I have never seen one up close /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Beaulieu
Remove the battery first as they do leak . Otherwise clingfilm over the brake resevoir and replace cap . Nothing else should leak .
A similar product is listed on the back of the April Eastwood mailer. It indicates you have to take off three wheels and drain fluids. Price $1,249.
