austin healey fasher unit
Roberte
I have a BJ7.
I recently removed my flasher unit (the small cylinder near the bulkhead. It has 3 terminals on it.) I'm not sure I have them connected properly. The terminal side of the flasher points toward the radiator. I think the center terminal is correct ( it is facing up toward the bonnet) but not sure of the other 2. Is the center terminal higher (toward the bonnet) leaving the 2 outside terminals positioned downward (toward the frame) or is the center terminal lower (toward the frame) making the 2 outside terminals face toward the bonnet I hope this makes sense to you.
Thanks for any assistance!
Robert
OH Better tell us the terminal ID on the base plate and the color code of the wires connected to each terminal.
