Good Afternoon All,
I've been trying to figure out an issue with my overdrive. It was working and then quit. I went through the test procedures and determined the Throttle Switch was bad. For good measure, as all of the electrical components in this circuit were over 20 years old (last time I had to replace any) I ordered in new 1. Throttle Switch 2. Both relays R1 and R2 3. The Dash Switch 4. Top gear switch 5. Solenoid (the centrifugal switch is by passed). Replaced all of the components, adjusted accordingly, changed the oil and cleaned the magnets and control valve. Out for a test ride. All works great. Went for a 200 mile club outing, overdrive performed great...until after exiting the highway and stopping for lunch. Upon continuing our trip the overdrive would not engage.
Problem: overdrive won't engage automatically
Double checked adjustments, checked and changed oil. Still will not work automatically. With cover off, can move linkage on RH side of overdrive and engage manually. Additionally, with switch on can lift up on solenoid plunger and overdrive will engage and remain engaged until slowing down as normal. Should this indicate the pull up circuit in the new solenoid has failed?
Thank you for any help,
Rob
Rob
Hi Guest!
