Re: austin healey 3000 hornbutton turnsignal switc
Hi Powell, for both of the cylinders,break the line fittings before any thing else is loosened. Then remove the clevis pins and unfasten the units from the bulk head.Now finish removing the line fittings from the cylinders and remove them from the car.When replacing them ,set them in place then fit the line connectors making sure they start and thread in using only your fingers ,add the shims and then tighten the bolts down. The bottom bolts will probably require installation from the botton of the car.Now finish tightening the lines up in the clynders with wrenches and hook the clevis fitting back up.Then bleeeed and bleeed again. Good hiqh quality stubby wrenches are an asset here.---Fwiw---Keoke /ubbthreads/images/graemlins/hammer.gif
