Well, early 20th century.
Just mic'd it at 41.5mmWhat size bezel on that, Basil?
Good choice on the strap. I have one for my Timex. The only way I can get the right fit on my wrist.I recently swapped out the stock stainless bracelet for this NDC Parachute strap. It's made from surplus French military parachute strapping. It's very comfortable and nice and stretchy, unlike many NATO style straps.
If you stare at it long enough LOL! It's a Flight calculator from which you can calculate speed, distance, time, fuel consumption, etc. Similar functions as a Breitling Navitimer but without the $6,000 price tag.Dang boss, with all the stuff on that watch it must do just about everything. Makes me dizzy looking at it. Can you actually tell time with it too?
I noticed that it has compass directions on the outer bezel... is there a compass in the watch? If not, how are the N,S,E,W settings used?If you stare at it long enough LOL! It's a Flight calculator from which you can calculate speed, distance, time, fuel consumption, etc. Similar functions as a Breitling Navitimer but without the $6,000 price tag.
The compass indices on the bezel are used to provide a rough indication of direction. This description is for the Northern Hemisphere: At night of course you would simply point the N in the general direction of the North Star and the other indices will point towards the respective directions (this assumes you can see the North Star). In the day time it's a little different. First you need to set the time to standard time (if you are in Day Light Savings time, you would reset the watch for standard [non-DLS] time.) Then, holding the watch level you point the hour hand in the direction of the sun (keeping the watch level - not pointing UP at the sun). Then, rotate the bezel such that "S" or south is pointed halfway between the hour hand and the 12 o'clock position on the watch. While in this orientation, the indices will point in the respective directions so you can tell which was is East, West, North East, etc.s there a compass in the watch? If not, how are the N,S,E,W settings used?
Oy.... It might be easier to get a bearing from the sun (assuming you can see it).The compass indices on the bezel are used to provide a rough indication of direction. This description is for the Northern Hemisphere: At night of course you would simply point the N in the general direction of the North Star and the other indices will point towards the respective directions (this assumes you can see the North Star). In the day time it's a little different. First you need to set the time to standard time (if you are in Day Light Savings time, you would reset the watch for standard [non-DLS] time.) Then, holding the watch level you point the hour hand in the direction of the sun (keeping the watch level - not pointing UP at the sun). Then, rotate the bezel such that "S" or south is pointed halfway between the hour hand and the 12 o'clock position on the watch. While in this orientation, the indices will point in the respective directions so you can tell which was is East, West, North East, etc.
It might be easier but that's actually a pretty accurate way to find north.Oy.... It might be easier to get a bearing from the sun (assuming you can see it).
Thank you for the detailed instructions.
