OK, some DO (notice I didn't say DPO) drilled the screw heads off the six mounting screws which go through the windshield posts into the windshield frame during disassembly because the screws would not budge.
Now it's time to deal with extracting the screws. Those small (10-32) machine screws are not budging. I have broken two Craftsman extractors off. I've used some heat, PB blaster, cussed at them and begged. No go.
I have another frame that is in worse condition that has the same broken off screw problem. So I used it as a "practice" frame to drill out and attempt to re-tap. I just made a mess of the soft aluminum frame.
Any suggestions out there?
Hi Guest!
I'm sure more will show up.
