Rob Glasgow
I am installing a new trunk liner in my BT7. I know that the piece that covers the bottom part of the shroud between the boot opening and the gas tank is glued to the shroud and I think the coachman loop that holds the spare tire holddown strap is mounted on top of the piece. It looks like this piece is long enough to fit under the edge of the gas tank. My question is which edge should go under the tank, the one with the finished binding or the raw edge?
The other edge will be glued up under the lip of the boot opening.
This is the piece in question.
