Carrying this over from my last posting on my starter/Ring Gear problems, when I went to connect the +12v battery terminal back to ground (always the last step, and this is a positive ground car) I got arcing and sparking.
My bad, because I had inadvertently left the negative battery lead that goes to the starter solenoid off and touching the body. After reconnecting that lead, though, and now extremely cautious, I’m reading +12v between the ground strap and the positive battery terminal. This “may?“ be normal, but I don’t think so, although I’ve never checked. The ignition key is off, and no accessories are switched on.
The solenoid seems to be ok: with everything disconnected from it, the ohmmeter reflects it closing when I push the button and I have an open circuit from the solenoid case to its upper terminal. Both of these are tests indicate the solenoid is good, but I do have a new solenoid coming anyways.
My thought is to test run a (fused) jumper wire from the positive battery to ground, but if someone could run out to their garage with a voltmeter, disconnect the (+) battery terminal and measure the potential to ground, that’d be appreciated (Assuming you have a positive ground car also). Or any other advice too! Thanks as always, Jim
