Application of Marvel Mystery Oil
AN6-TX
Rather than high-jack the "peanut butter" thread, I figured I would start a new. There were a few mentions of using MMO in the other thread. I'd like to confirm that my understanding is correct. That is, MMO is being added to the engine oil, correct? And at what concentration?
Many thanks!
Stan Kowznofski
I usually use about 20%, that would be 1 quart Marvel in a 5 quart system. I also add about 2 ounces to 5 gallons of fuel and have found less galling, pitting, etc. on aluminum surfaces in the fuel system. I use it in my car as well as lawn mower, garden tractor & snow blower. It helps to alleviate some of the wash-down caused by the alcohol in fuel. For full disclosure - I am not now nor have I ever been affiliated with the company, I learned to use it 50+ years ago hanging around with hot rodders & racers who swore by it.
JPSmit
I don't use MMO I use Lucas oil stabilizer - 20-25% (1 quart per oil change)
SaxMan
You can put it in the gas tank as well. That seems to have yielded a more noticeable result for me than adding it to the oil. Maybe because I'm dropping so much oil (I usually have to put in a quart every 200 - 300 miles), it really doesn't have have a chance to do its job.
This winter I'm going to take a shot at Seafoam, which I am told is like Marvel Mystery Oil on steroids.
AN6-TX
AN6-TX
I've used Seafoam on my daily drive ('11 Grand Cherokee) occasionally. It certainly does something... :smile:
SaxMan
The Seafoam seems to be working nicely. I took the Sprite out for it's first jaunt in 2019. Even though I still need to tweak the carbs, the car ran really strong. Part of it might be I've gotten more adept at my valve adjustments than I have in the past more than the Seafoam. The more notable application of the Seafoam was that I put some in the gearbox. I can't recall the tranny ever feeling as smooth as it does now when rowing through the gearbox.
LarryK
My brother in law being a missle engineer had bought an Opel Gt and ran it for 300,000 miles on MMO exclusively, only changing the filter and topping off. One of his many experiments. Engine outlasted the body.
Joe Schlosser
Does any one know what MMO is composed of??
JPSmit
Mystery Oil :jester:
from wikipedia
It is composed primarily of petroleum distillates, including mineral oil (60-100%), mineral spirits {10-30%}, tricresyl phosphate (an antiwear and extreme pressure additive in lubricants, 0.1-1.0%), ortho dichlorobenzene (a softening and removing agent for carbon-based contamination on metal surfaces, 0.1-1.0%), and para dichlorobenzene (a precursor used in the production of chemically and thermally resistant polymers, <0.1%).
and another website
I borrowed this from another thread, I've pasted this into a few threads before HTH. I would follow the suggested OCI for a vehicle and not run MMO if you plan on extending an OCI beyond what the mfg suggests.
70% Light Aromatic Oil (Pale Oil)
- It is a Naphthenic Oil, so while it oxidizes faster than a Paraffinic oil, it does clean and dissolve sludge and carbon well and cleans up after itself from any oxidation. serves as base oil as well. [Naphthenic oils have more solvency and are more polar (they are attracted to metal more), but oxidize faster.
29% Mineral Spirits
- Cleans Varnish very well. General cleaner. Also acts as an antioxidant.
38 parts per million (ppm) Boron
- AW/EP agent, friction reducer, antioxidant
900 ppm Phosporous
- AW/EP agent
1/2% 1, 2 ortho-Dichlorobenzene
- EP agent as it interacts with Iron to form an Iron chloride barrier under any ZDDP or other AW additives. Also very good cleaner/solvent, and friction reducer
1/4% 1, 4 para-Dichlorobenzene
Oil of wintergreen - for the scent
- Not just for the cent, is also a cleaner. may aid lubricity.
Red Dye - for the color
- well this one just colors the stuff
Jim_Gruber Speedi Sleeve required for this application - Need advise! Spridgets 12
KVH General Tech Clear Coat Application Triumph 6
DNK What application? Triumph 9
prb51 Tool application and definition Restoration & Tools 0
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
AngliaGT Anyone Have Import Heater Hose Application Book Other Cars 0
T Disc grease application? Triumph 12
glemon Moss Engine Paint Application Austin Healey 5
TR4nut TR4/4A Speaking of Webers - TR4 application question Triumph 38
Lin Seam sealer - original application Austin Healey 2
bmurphy7369 BW-66 or 65 trans application questions... XJ6 III Jaguar 1
A Positive Ground Application - Coil Polarity Hookup Austin Healey 15
tahoe healey Inline Fuses [ and Fuse Theory & Application ] Austin Healey 19
S Marvel Mystery Oil Spridgets 7
A Marvel Mystery Oil Austin Healey 18
af3683 Marvel Mystery Oil Triumph 24
K TR2/3/3A Mystery TR Part Triumph 9
Celtic 77 MGB Mystery cylinder head attachment. MG 4
A For Sale Mystery brass intake manifold Other British Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
equiprx Mystery part Other British Cars 2
BoyRacer Austin A90 mystery engine British Motor Corp 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
BoyRacer Mystery 3000 Engine Block Austin Healey 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
D TR2/3/3A Another mystery part(s) Triumph 2
S MGB mystery wiring plug MG 2
jehuie Morris Minor horn mystery British Motor Corp 12
D TR2/3/3A Another mystery part Triumph 8
Sixpack TR6 Horn Mystery Triumph 3
M TR6 Mystery Switch Triumph 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
J TR2/3/3A TR3 gas tank mystery Triumph 5
M TR6 Fuse box wiring mystery Triumph 9
S MGB mystery wire MG 32
somewhatspritely Mystery Screws Spridgets 5
Healey Nut Mystery Part Austin Healey 2
D TR2/3/3A Another mystery part..or two Triumph 14
B 2013 Nissan Frontier front end mystery Other Cars 7
B MGA Mystery bolts MG 2
P Mystery Lexus?? Other Cars 10
T New Generator Mystery Austin Healey 5
B MGA Mystery MGA chassis part MG 3
K TR2/3/3A Mystery stall and no start? Triumph 7
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
J TR2/3/3A Mystery Wood Triumph 7
K Mystery badge bar Other Cars 4
P Mystery Car Other Cars 11
