FYI:
Just contacted Valvoline as to their recommendation for transmission/differential oil for our Triumphs.
My email to them:
Hi Valvoline: I'm looking for a suitable lubricant for a 1973 Triumph TR6 differential+Manual transmission. The shop manual calls for: "BP Gear Oil SAE 90EP" -OR- "Castrol Hypoy" -OR- "Duckhams Hypoid 90" -OR- "Esso Gear Oil GX 90" -OR- "Mobilube HD 90" -OR- "Petro-Fina PONTONIC MP SAE 90" -OR- "Shell Spriax 90EP" -OR- "Texaco Multigear Lubricant EP 90" =>>All of which are spec'd to be API GL4. As you know, most oils nowadays (and all the oils on the shelf at my local shop) are GL5--although some are GL5/GL4. The problem, I've been told, is that GL5 isn't good for yellow metals.
Which of your products do you recommend for this application?
Their response:
To meet API GL-4 standards, we produce the Valvoline Synchromesh Fluid (part number 811095). The Synchromesh product is 100% safe and compatible to metals used in GL-4 applications.
Anyone have any comments before I go buy a couple pints?
My email to them:
Their response:
