Hap Waldrop
jlaird said:Also keep in mind that the rear wheel car width is greater than the front.
Maybe I'm not reading you right, but just in case, on Spridgets the front track is wider than the rear, so that difference has to ba taken into consideration when stringing a car.
Most racer string align their cars, I even inherited a Dunlop site aligner, and sold it, because I have string alignment set up down to a science. What stringing a car does that simple toe setting devices don't is make sure the car car tracks straight.
You also need some turn table for the fornt wheels, so they move freely as you make adjustment, now when you check the price of turntables you be in for a shock, they are not cheap, but not to worry, you can make yourself some tuntables on the cheap that will do the job just fine, I have four square of .125" aluminum palte, I use a mixture of wheel bearing grease and WD40, then sandwixh two of the plate together, repeat for the other side, then roll the front tire on them before you set up your string rig, you can do this even simplier, go get 4 commercial vinyl tiles, they will owrk as well as the aluminum plate.
This is a simple basic deal, but it works excatly like the expensive computer aliginment machine, same exact principal.
As for the floor needing to be exactly flat, not really, yeah you don't need any drain dip in the floor, r one tire sitting in a pot hole, but its not like scaling a car, reasonably flat will work fine. I align my race cars at the track before sitting in the grass.
