motofiaccone
Re: Anyone running with 14's or 15's on a Spridget
Feck! Is that what those things cost? I may be reevaluating the direction of his project.
If I'm not mistaken, the gs and the gsl had a different bolt pattern than the gsl-se. You might be in luck.
--chris
Branson said:Chris,
I believe the RX-7 rear end is 4x110mm. I will have to have my GSL rear end re drilled to the 4x4 pattern. BTW, Moser has axles for the RX7 rear for something like $315.00 ea. you can order them with the spridget lug pattern.
--chris
