Re: Anyone running with 14's or 15's on a Spridget
Nevermind, I just read the post above. I'll research this a bit more to see if 1.) redrilling is possible, 2.) if it is worth the trouble and 3.) if the 14" wheel/tire combo will work. I love my Falken Azenis' that I run on my se7en, so maybe they will work on the Midget.
I also might be in a different situation than some because I'm running the RX-7 GSL-SE rear axle, which has the 4 on 4 bolt pattern. So either way, the front or the rear will need to be redrilled.
--Thanks, Chris
