TR4/4A Any tips on running the overdrive switch wiring down the steering column?
tdskip
Hi guys. The '67 TR4a did not originally have an OD so I need to run wires from the newly added switch... Anyone been there/done that and have some lessons learned to pass along?
Extra bonus points for ideas that minimize having to disassemble stuff. Grin.
Thanks!
Geo Hahn
I did this on a TR4 -- just ran the wires down the same 'dagger' as used for the turn signals, etc. That area may be a bit more crowded on a 4A if (as I think) the headlight switch is on the column and uses that same route.
I had to add a D-shaped hole in the right side nacelle, maybe you will too.
DNK
Those "D" shaped drill bits are getting to be a bit pricey
Andrew Mace
It is arguably easier to purchase the proper escutcheon, part number 611974, which has space and other provision for the correct OD switch. Readily available from all the usual suspects! Of course, this advice applies only to the TR4A and later, as Geo suggests.
Geo Hahn
Are the replacements metal or plastic (I honestly don't know). When I did mine it came with a right hand escutcheon with D-shaped hole but it was plastic -- I chose to drill my original metal piece.
TR4nut
I think the plastic/metal cutover point was right at the 4/4A change. On the 4A the switch is on the left side, doubled up with the turn signal switch. For TR4 the right one had the d cutout for the switch if overdrive was installed.
T
tdskip
I believe that is correct, how I am planning to do it unless Don can find that D-shaped drill. Ha.
DNK
Let me dig thru my drill drawer, Tom.
Until then. Better get your credit card out
Gliderman8
Hey Tom... welcome back by the way!
Since don can't find his D-drill, you might consider going to a square drill bit. Yes, I can supply one if needed....
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
J Tips for quarter elliiptic spring install Spridgets 3
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
PC DIY tips from Bo his self Other Cars 0
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
drooartz Installing front hubs, tips? Spridgets 15
bugedd Bench bleed tips Spridgets 14
S TR4/4A Electrical wiring tips Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
F Buying a 100.... tips Austin Healey 18
drooartz MGB Changing clutch hose - tips? MG 13
T Tips for Searching FORUM Navigation Questions 2
T TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild Triumph 7
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M tips please on removing starter motor on 100-6 Austin Healey 6
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
bugedd Su adjustment tips Spridgets 7
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
PatGalvin TR2/3/3A Carpet Install Tips Triumph 12
Bob_Spidell Tips Austin Healey 6
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
W Looking for tips: BJ8 roll up windows Austin Healey 10
I TR6 Any tips on removing flasher switch Triumph 3
M Radiator Hose tips? Spridgets 0
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
bugedd About to rebuild front end...any tips? Spridgets 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
apbos Two Restoration Tips Spridgets 11
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
5 TR2/3/3A TR3 engine building tips needed Triumph 5
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
T Wheel cylinder fitting kit - any tips? Triumph 4
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
J 67 IRS Exhaust Tips Triumph 2
RickB Painting tips anyone? Spridgets 13
RJS Water Pump Replacement Tips Triumph 8
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
aeronca65t Kasnter tips Triumph 8
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
JodyFKerr Tips & tricks on installing upright air compressor Restoration & Tools 15
drooartz Any tips for replacing brake hoses MG 16
