TR4nut
Thought I'd tap the collective wisdom here one more time. I've been working through the 3A I recently acquired - car sat for about 4-5 years until my purchase. After I got it restarted from its slumber my fight turned to the overheating problem and I'm still fighting it.
Here's what I've done so far:
Replaced radiator with an unholed one - good improvement
Changed out waterpump/thermostat.
Checked and slightly adjusted capillary gauge to read 212 in a pot of boiling water.
Tested radiator for exhaust gases - came back negative.
We are starting to get cool weather in Texas - on Saturday I took it out for a long jaunt, maybe in 80 degree weather roughly. You could see the car get to operating temp nicely and see when the thermostat opened. Over the course of about a 1 hour drive, with a breakfast break in between, the car very slowly increased temp to near 212 - even with the heater on. I reran it in the garage without the heater on, but blowing from a shop fan into the radiator, and I still climb to 212+. It does not seem to ever stabilize to a running temp. This does not seem at all right to me.
The car does not pop or belch fluid on shutdown - but it clearly is hot. I suspect an exhaust manifold leak so will be pulling that anyway. While I'm in there I'm strongly considering pulling the head 'just because'. I do have a spare head and new head gasket I can install and it will give me a chance to look at condition of lifters etc even though that is not an overheating issue.
Any ideas? Wishful thinking on my part? I'm running out of thoughts here.
