wkilleffer
Hi everyone,
I have a question about odd behavior from my Craftsman 21" pushmower. It has a 4.5 HP Briggs engine and is equipped with mulching and bagging capabilities.
Last year, I hit a piece of metal in the yard. This resulted in a bent crankshaft and broken blade adapter.
I had the crankshaft straightened at a local small engine shop, and the engine seems to run like it did before the incident. I went down to the nearby Sears Essentials, but they were out of blades and blade adapters. A nearby hardware store had them.
The person at the hardware store said that the mower should be able to use an adapter with a star-shaped fastener, which would allow me to use a readily available blade with a star shaped hole. I bought them and installed them according to instructions.
Everything seemed ok for about 10 minutes, and the mower started making a knocking sound. I checked the oil, but all was ok. I looked under the mower, and the blade adapter had fragmented. I took it back and got another one, and it's done the same thing. I gave up on getting the yard mowed today.
Now, this can't be normal. It doesn't seem likely, but could the engine be causing this?
Also, since it's a Sears-branded mower, is it going to require Sears parts? I've known them to require that on some things like this in the past, but I was hoping to avoid a trip to the mall.
Also, could this have caused any more engine damage?
Thank you,
-Bill
Thank you,
-Bill
