After having my tr4 chassis sandblasted it's almost ready to start sticking stuff back on it and my first order of business is to refurbish the suspension with new bushings etc..i've checked the 3 biggies (Moss,TRF, BPNW) for kits. BPNW is by far the cheapest but out of stock so that leaves TRF and Moss. I was sort of leaning toward Moss and using the solid polyurethane upper wishbone bushes which are solid one piece instead of the 2 standard rubber ones and would be an add on to the kit..but then I noticed TRF has a bush set already comprised of urethane in one of their kits..Now I'm thinking that is the way to go and less cost than Moss.
So my question is: if just using the basic standard kits for comparison, does anyone have any quality or fitting issues experienced from one vendor or the other? I would assume all would be exactly the same but then every now and then I get burned from that idea..
Thanks
Thanks
