General Tech Any good ideas for removing liners?
Sarastro
I'm working on a second engine, which came with my TR4A. It's a TR4 engine. I'm at the point of removing the cylinders, but they are really tight. Pounding away on a wood block hasn't worked, nor has using an aluminum block instead of the wood. I am reluctant to be more aggressive, as I don't want to risk cracking the block.
The problem is complicated by the fact that two pistons are seized in their cylinders. For that reason, tricks like making a puller won't work, at least not on those two cylinders. I'm thinking of pouring something into the coolant area, maybe phosphoric acid or a weak solution of muriatic acid, and letting it sit for a day. Or, something like that.
Any other, maybe less scary ideas? I don't care about the cylinders or pistons; obviously, they will have to be replaced.
Rut
Steve,
Im sure you’ve tried solvents and such, but Kroil is moving up on my list of most effective penetrating oils. I would give that a try along with a good aluminum drift...I made mine out of 1.5” square stock about a foot long. If that doesn’t work, clean out the oil and give phosphoric acid a try, but don’t let it dry. Good luck and let us know how it works out.
Rut
TR3driver
Great Pumpkin - R.I.P
I made up a 'drift' long ago that seems to work pretty well. It's just a length of galvanized water pipe, with an iron cap on one end, and a hex brass cap on the other. I put the brass against the edge of the liner, and whack the other end with a 3 or 4 pound sledge, then move to the opposite side and repeat.
For the stuck pistons, just go after them with a long cold chisel. They break pretty easy, and as you pointed out, you don't have to worry about damaging the liners.
I've never needed a puller, but the idea sounds interesting to me. Be sure to spread out the load on top of the block though, that upper surface is surprisingly fragile.
TomMull
I made a drift, from Randall's instructions I think, and it worked for three. The fourth wouldn't budge so I put it on a big press and pushed on the piston which was stuck also. That broke the liner just below the piston which so I pressed the piece out separately. Luckily, I did not damage the block. Next time I'll use the chisel and get some Kroil.
Tom
Geo Hahn
I also used a 'Randall' on mine - really has a 'something's gotta give' feel when you whack it with a 3 lbs hammer (about all I could swing while laying on my back).
Guess I am "backwoods" on removing pistons. Years ago Dad whittled a piece of hickory firewood down to the size it would just fit inside the liner. A couple of licks with sledge hammer and piston is out. No problem with liners but imagine I would do the same with them.
Marv
tomshobby
I purchased a new 64 TR4 in the spring of 65. and replaced the pistons and liners I don't remember any trouble removing the liners probably because of the age of the car at the time so this would not be of any help.
The reason I am posting this trivia is that I remember reading, at the time, an article that was recommending every 12,000 miles or so that removing the head and rotating the liners 1/4 turn could extend the engine life by reducing wear or causing a more even wear pattern. I do also remember thinking it seemed quite silly. I never tried it and have never heard of it since.
glemon
I believe bores tend to "oval" over time, and not simply wear into a bigger and bigger round hole, so this probably makes sense to do if it was as easy to do as rotating your tires and changing you spark plugs.
Sarastro
Sarastro
Guys, thanks for the suggestions. As with many things, I think this is a case where you try a bunch of things and eventually one works. I didn't have this problem with the engine now in my TR4A chassis; the cylinders needed only a decent whack with a hammer and wood block.
There are a couple examples of pullers on the internet. They are all variations on a theme--a block under the liner, some threaded rod, and a bridge at the top. Tighten the thing and maybe give it an extra whack from underneath. Kinda like I do with tie-rod ends.
I do have a three-pound sledge. Next, off to Lowes for some plumbing bits...!
Sarastro
Sarastro
I got the li'l buggers out!
I found a piece of aluminum that was about the right size, used it as a drift, and gave one a whack with a small sledge. After a couple hits, I could feel the first one moving a bit, and it got easier as it moved farther. The rest required about the same effort.
I still have two pistons stuck in their cylinders. One is no longer frozen, but it will take some force to get it out. I will try my press on them. If that doesn't work, I'll cut the little mothas apart with an angle grinder and cutting disk. The only things I need are the connecting rods; the rest is trash.
Thanks again for the suggestions. Sometimes, it's helpful just to discuss these things--it gets ideas flowing.
Rut
Woohoo! If something goes wrong and a rod gets injured, the MaxSpeedingRods are really nice and they’re cheap. I’ve bought a few sets for LBCs between $250 and $300 and when I compared them with resizing, reducing weight, balancing, and adding ARP hardware it was pretty close.
Good luck, Rut
CJD
Use the same sledge on the crown of the pistons and they'll break out in one big whack!
Sarastro
Sarastro
In the end, I just cut the cylinders with my angle grinder. Took about a minute each, then just a tap with a hammer and chisel to break the halves apart.
It's funny, here in LA we always expect everything to be stupidly expensive, but there are bargains everywhere if you look for them. With my first engine, I was sorely tempted by the MaxSpeedingRods, but in the end, the desire to keep costs down won out. I paid $215 for all the machine work, which included sizing the rods and inserting/reaming the small-end bushings, regrinding the crank, resurfacing the flywheel, and balancing everything. They did a nice job; I checked all the dimensions, and everything was right.
TR3driver
Who did your machine work, Steve? I'm gonna need some of that myself in a few months.
Sarastro
Sarastro
The place is
Engine Parts & Machine
5036 Firestone Pl.
South Gate, CA 90280
323-569-3035
They also go by Ali's Machine Shop. Dunno the reason for the name confusion--maybe the business was sold.
The details--$55 to regrind the crank, $12 ea. to recondition the rods, install bushings, and hone them, $22 to resurface the flywheel, and $100 for all the balancing. I had remembered $215 but it actually came to $225.
TR3driver
Might have something to do with there also being an Ali's Machine Shop in Signal Hill :smile:
Rut
The place is
5036 Firestone Pl.
323-569-3035
Wow, that’s a really good price for everything!
Rut
Sarastro
Sarastro
I think it's the same Ali's, but it moved. Based on Yelp and recommendations, I tried to take my stuff to the Signal Hill location, but it was gone.
As for the pricing--I know a crank grinder in South LA that will regrind a four-banger crank for $35. I had my MG TD crank done by them. Kind of a creepy part of town, and their building looks like a place someone would take you to murder you, but they did a nice job.
D Ideas for removing retaining ring? MG 3
S Wedge Ideas for removing paint from TR8 bumper? Triumph 4
B Cove Paint Color Ideas Austin Healey 10
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
pbraun Ideas on tires for Bugeye with 13x6" wheels Spridgets 3
nathandarby67 Ideas for organizing hardware when plating Restoration & Tools 6
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
Jim_Gruber Need your ideas on a How To Do it - SpeedHut Gauge Install Spridgets 11
Rut TR4/4A Shop with lift ideas Triumph 21
maxwedge5281 third brake light ideas Austin Healey 34
B TR6 Seat Belt Brackets - Any Better Ideas? Triumph 1
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
chuckmcb Baffled by BJ8 Ignition light...any ideas? Austin Healey 9
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
trotti Stuck drum - any ideas? Austin Healey 5
CJD TR2/3/3A Engine Storage Ideas Triumph 2
T TR4/4A Lowering my TR4a - ideas? Triumph 18
catfood Any Ideas? Austin Healey 7
aeronca65t Christmas Card ideas Other British Cars 5
RickB Any temporary Bugeye grille ideas while I send mine off? Spridgets 16
bthompson Using the brakes kills the engine! Any ideas why? Spridgets 17
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
RJS Top Frame Repair - ideas needed Triumph 8
Mychael Ideas for a parcel shelf in a Frogeye Spridgets 8
T ideas on fixing - one carb keeps "rusting" Triumph 4
I TR6 TR6 difficult to start - ideas? Triumph 6
M Any Ideas Triumph 26
K Any ideas for a Handbrake Warning Light??? Triumph 11
bighealeysource ideas on how to fix dents on frame Austin Healey 15
Darrell_Walker Alternator cleaning ideas Triumph 10
ahealey1004 bn4 drum brake issues...any ideas? Austin Healey 7
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
Brosky Upholstery makers in England? Any ideas? Triumph 21
T Ideas on fixing this? Triumph 19
eschneider leakdown test readings - ideas? Restoration & Tools 12
D help...? Air Filter ideas needed...nothing fits! Spridgets 23
A TR4/4A TR4 mistery engine problem - any ideas Triumph 14
startech47 Any ideas? Spridgets 8
gubba Slight front end shimmy @ 52 mph any ideas? Triumph 13
T Ideas on getting this bolt unstuck Triumph 42
RickB New steering wheel, ideas about adapting? Spridgets 23
bighealeysource Ideas on where to get ID plates stamped Austin Healey 3
M Need Engine Swap Ideas for '76 Midget Spridgets 21
T TR2/3/3A TR3A vibration - looking for ideas Triumph 38
RickB Ideas about modifying seats to fit rollbar? Spridgets 6
