fordtrucks4ever said:You may be able to bore your existing m/c out to 7/8. Should be much cheaper than a resleeve and then good as a new one. I recently picked up some small bore mandrels for a Sunnen. If my 3/4" m/c doesnt clean up well enough to use, it will be bored and honed to 13/16 first, and then 7/8 if I goof. If nothing works, then it gets resleeved. Right now I dont have anything to loose, since car is a long way from completition and having the equipment to play with, its hard to pass up. In the end, if all I need is a new master cylinder to finish the car, i can justify the expense.
JPSmit said:can you get the seals that size? is there a way to order them by size rather than model?
jvandyke said:I think you need "correct" seals though. I found this out the hard way as well, any old 3/4" cup seal won't cut it, it has to have the correct "skirting". I documented it here a while back. I imagine that to be true for 7/8" also. If you have the tools and ability and time to mod a 3/4" into something else, I'm jealous. I bought a decent 7/8" rebuildable for $25 and went on to something else.
Here's a picture from that other thread
tdskip said:Well I'm glad I asked;
Are you folks saing that #2 180-970 $12.55 REPAIR KIT, clutch & brake
from Moss won't work properly?
nomad said:I've had both the 7/8 and 3/4 on disc front brake cars and while the 7/8 will work I believe you will appreciate the better pedal feel of the 3/4 if you can save it. They are like hens teeth so if you don't use it pass it on to someone who will. 3/4 that is.
KA.
tony barnhill said:Has anybody called Moss to see if they know about the problem? & what their solution is?
