Most AF bottles have a graph or chart to give an appropriate concentration for expected ambient temperatures. Since you live in FL, you probably need about 2 tablespoons
But seriously folks, you probably don't need much; maybe a quart or two, or use with some blue ice or water wetter.
antifreeze is not just for cold weather. Its also a coolant. As important in a hot environment as it is in a cold one.
As for water used, I use distilled, non mineralized water, though I cannot find non mineralized water so easily anymore. And I do believe the purpose for this is, at least in part, to prevent acceleration of rust deposits or other impurities that can harm your pump, block, etc.
but it used to be a lot easier when I could buy it right off a supermarket shelf. no more.Most of the well known water companies will deliver it right to your front door???
The local Publix (in Florida) still stocks deionized water, and I buy that when I remember to. Kroger's in Ohio also kept it on the shelves, buts it's been four (>4) years now since I've been in one of those!but it used to be a lot easier when I could buy it right off a supermarket shelf. no more.
If it's not with the other jugs of water, it will be with the baby formula. BTW, if you use it, you must mix it with anti-freeze as it's really corrosive by itself.but it used to be a lot easier when I could buy it right off a supermarket shelf. no more.
