Hi Guest!
----- heck if we told ya about all the "pit falls" ya might sell the car and wed have no one to type at! did you get the drain tap out in one piece? ive known guys that used teflon tape and others that have used generic types of anti-seize some guys use nothin at all,some use a sealer but ive never had to do that, i use "milk of magnesia" works every time this compound is also very good on anything that gets hot i.e exhaust fittings etc, there really isnt a special one to use if anyone tells you so its only cuz its their fav, or have had success with it the past., such as myself,--- "three times as long to get the water pump out"- hay welcome to the forum. --- keoke, enter stage left... /bcforum/images/%%GRAEMLIN_URL%%/grin.gifAndy65 said:Any recommendations for the type of anti-seize or other lubricant for drain taps? I know grease is not a good thing.
The radiator came off easy. No one said it would take three times as long to get the water pump off the block.
That's my nomination for quote of the week!Andy65 said:Keoke, I can see using Coppaslip for the tap threads, but do I really want to use Coppaslip as lubricant inside the valve? Seems like it would be gooey. Plus, how does the copper react with the antifreeze and will it dissolve water? There is a lubricant for ball valves and I'm going to find it!
Good group of people here - kind of like BJ8 brake drums - slightly off balance but functional.
It will be great to get the Healey back on the road.
There is a lubricant for ball valves. I just rebuilt my kitchen sink ball type (the single handle type) valve and used this lubricant. It's available in small quantities at Home Depot.Andy65 said:Keoke, There is a lubricant for ball valves and I'm going to find it!
