G
When fitting the front swaybar today I disconnected the radiator to get some room. to get the the offside I had to remove the canister and the "anti-run on valve".
Two problems:
1. There are two electrical connections going into this thing. They weren't connected and I'm not sure which of the loose wires lying around they are, and the manuals are useless. Can anyone help?
2. There are two hose connections into this thing. The first is from the canister above. That one is fine. The second is a smaller diameter. The BL manual describes it as a "vacuum signal pipe". It is missing (actually the connector is broken off as well). Can anyone tell me where it goes to?
Oh and the final question - the car seems to be running ok without this stuff. Should I let sleeping dogs lie? Fix it? Get rid of it?
TIA, Alan
Two problems:
TIA, Alan
