anti roll bar
HI JM, About the upper bracket where the end link fittings go it is the weak link in the chain. I will eventually beef them up with a stay but simply straighted them this time. See you later---Keoke
Well, that was worth having a beer or two over. I've really enjoyed reading this thread and my aim was achieved: I learned a lot more about handling.
I've changed to other tires (185/15) which has already improved the handling of the car.
But as I don't intend to go racing, I am most interested in, like James presumed correctly /ubbthreads/images/graemlins/thumbsup.gif, that I want to upgrade to a 7/8" full bolt-on kit with polyurethane bushes.
In a second round I'll then consider other springs, etc.
As soon as I've done this, i'll let you know if it has made a difference. Maybe I'll be able to discuss this with some of you at the International Healey weekend in the U.K.
Cheers--- /ubbthreads/images/graemlins/cheers.gif Higgins
After fitting an uprated bar my brackets on the wishbone eventually cracked. Mind you they were 40years old and corroded. I got new ones from Denis Welch - apparently they use the same on the racers
