Ohiobugeye
After much debate as to what tachometer to use I bought a Smiths rvc 2415 negative ground tach to use. This tach. is 4" and will fit in my dash, it is also negative ground and is compatible with my electronic ignition. My question is, the tach has 2 wire connections on the back one bullet and one spade. Looking at the wiring diagrams I have found on the inter net it appears the bullet connection goes to the negative connection on the coil and the spade connection goes to the white (12 volt) wire connection on the ignition switch, I assume the ground is by the attaching bracket on the back of the tach case. Anyone know if this is the correct wire attachments? I thought I'd double check before I hooked it up and fried it. Thanks, Don
