Spitfire another Spitfire question - stuck rear hubs
eschneider
Doing rear wheel / hub seals on a MKIII spitfire, and the hub flange is really stuck on the axle. Taking a breather before breaking out the torch tomorrow.
So far have used a hub puller and BFH with some pentrating oil, an impact gun, and a MAPP torch.
I'm sure this is just an elbow-grease PITA, but thought I'd throw it out there in case someone had some words of wisdom or cautionary anecdotes.
trrdster2000
Heat is one way, caution on too much, as it will bend the axle. I have a couple in the corner that never came apart and one that still had the puller on it when I chucked it, and that's when it busted apart, so good vibrations, (whacking it with a air hammer under load from a puller has worked for me in the past.)
Wait till you try a TR6 one, it involves dipping it in a volcano and two Ford F350's pulling, long story.
Good luck, Wayne
71MKIV
It could also involve the puller and 50 ton presses and if you're not careful bent hubs.
Is the axle out of the car? Sometimes it makes this job easier.
run the puller up as tight as you can, spray liberally with penetrating oil, a block of hard wood and bang on the hub. walk away and let the oil work.
come back and hopefully get a little more grunt on the puller, more oil, more banging.
I have it in the back of my head that the "official" way of doing this is to throw the axle nut end down onto a block of wood.
Another way, but you are on your own here, is to loosen the nut, and take the car around the block, slowly. then try the puller.
Soak the whole thing in dry ice for several hours, then use the puller and a torch to warm up the hub. I've used that trick for getting axles out of large gears here at work.
The hub is sitting on a taper, getting it loose from that taper is a PITA.
Platinum
Hateful job. Done 'em with press and whacking, heat-wrench and penetrant. This may be a candidate for the Weasel Pee concoction. 50/50 ATF and acetone. This thread has the skinny on it.
dklawson
I dealt with this recently on our Mk4 project. As above really...
What worked for me was to get everything out of the way (brake parts) and apply heat to the cylindrical portion of the flange casting that is seated on the tapered end of the axle. I used MAPP to get as much heat in there as quickly as possible. Turn the axle as you put the heat into the flange so it "grows" all the way around. In the end it was the combination of quick heat application after the puller was tightened AND a few sharp blows from a heavy brass hammer.
Whatever happens, don't become frustrated to the point that you start pounding on the hub.
PAUL161
The (Weasel Pee), Doc you crack me up :jester: ,50/50 ATF and Acetone, and a little of this :hammer:, was what broke the drums loose on my 55 year old Ford tractor. It took a week of soaking and banging, but they finally broke loose. All I use anymore.
Scott_Hower
You're in Phila. If you feel like making a roadtrip to the Lehigh Valley, I'll loan you my Spit hub puller from Canley Classics.
HerronScott
Most of the ones we did for my wife's Spitfire involved taking them to a machine shop to press off (making sure they didn't bend the hub in the process).
Scott
eschneider
eschneider
Tease! Do you REALLY think you can post an intro like that, and then NOT tell the whole story?
Get typing..... We gotta hear the whole story. <grin>
eschneider
eschneider
I may take you up on that. I'll definitely hold you to a shop tour next time I'm in the area. 8)
71MKIV
weasel pee? I thought it was mouse milk!
You all have it ALL wrong....here's what you do! :banana:
First, sneak one of SWMBO's good pans out of the kitchen while repeating "Pan, what pan?" to yourself. Then, drill hole(s) in the bottom that just HAPPEN to match the mounting arrangement of the car while repeating "Hole(s), what hole(s)?" to yourself.
Once the vessel is firmly mounted to the vehicle, take a leisurely walk around the neighborhood, visiting everyone you know to see if they have an appropriately aged wee one - 3 to 5 works best. Offer to watch over said wee one for 2 hours to give your now BEST neighbor friend(s) a chance to go to a movie or enjoy 2 hours of peace. Return to your domicile, ever watchful for SWMBO to see if the pan, what pan? has been missed. Show the pan, what pan? to the wee one and tell him or her there are jelly beans behind the pan and he or she can have them.
Now go inside and make a peanutbutter and jelly sandwich and get a glass of milk and return to the car. Not only will the pan, what pan? be off the car along with the flange, but in all likelyhood the rear end will be out along with the rest of the suspension and you will find a bewildered wee one who found no jelly beans. Hand the wee one the sandwich and milk after cleaning them up as best you can and slowly walk them home while they enjoy their afternoon snack!!
:jester:
Bob Claffie
The official tool is a "Churchill Press" anything less and you will almost certainly bend the flange and turn it into junk. Perhaps that is the tool Scott has, if so, it would be worth paying freight both ways for the opportunity to borrow it. Bob
Trevor Triumph
Shops used the press and I had to find new hubs. When the hub let loose it sounded like a cannon I'm told.The puller, Kroil, air wrench, and lots of time seem to be the ticket.
T.T.
billspit
I too will go on record saying to get a legitmate Churchill-type puller. I have done six axles (some more than once) and they are the ticket. Pretty much anything else risks damaging the hub. An expensive machine shop ruined some of mine using heat and a press.
I will say that I have learned to hunker down on the puller and give the axles a few good whacks. And leave the axle nut on but backed way off. First time I used the real puller the axle went one way the hub the other.
tomgt6
Looks like a great car. I wish mine was in that type of shape. Some day we will have to put on new rear fenders, rockers and floors.
Scott_Hower
Not the official "Churchill" tool, but a puller specially designed for pulling small Triumph hubs.
It bolts flat against the hub, so no chance of bending it.
TR3driver
Great Pumpkin - R.I.P
Pretty close to the original Churchill tool
eschneider
eschneider
So....
When I left the shop last night, the axles were sitting by the door, waiting for a *supervised* visit to the machine shop.
When I arrived this morning, I was greeted by a proud, beaming co-worker who had "taken the bull by the horns" and used brute force to seperate the hubs from the axles. He was so exuberant with his victory that he hadn't noticed that both hubs were bent to the extreme that the lug bolts were bowed inward, and one axle shaft bent/buckled at the threaded end.
ugh.
myspitfire
The right way is find proper hub puller.Its called a 'Churchhill Puller'A factory device.The only way you won't bust everything to pieces.Their are people over at 'Nass' that concievably could lone you one if your nice.And if you do find one hang on to it they are rare. :winner1:
T Spitfire Save another Spitfire from who knows what Triumph 26
Darwin Spitfire Another mystery to be sloved with my spitfire Triumph 8
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
AngliaGT ANOTHER TR6,& an MGB Spotted 0
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
D TR2/3/3A Another mystery part(s) Triumph 2
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
D TR2/3/3A Another mystery part Triumph 8
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
D TR2/3/3A Another mystery part..or two Triumph 14
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
AngliaGT Another MGB Spotted 0
J Another Healey back on the road....for now. Austin Healey 8
