Did I read somwhere that others have pulled the wires thru the tube one at at time and some have pulled the "whole" harness thru all at once. I've read the info on the forum from 2012 where this was discussed but I'm not sure of the best way. I have a cloth bound harness and was wondering if I would be further ahead to remove it and wrap it with vinyl before the install to make things easier? Does the stator tube slot run the entire length of the tube? The couple of inches of the stator tube that are showing(at the wheel end) appear to have the the two sides of the tube slot overlapped a bit and I was wondering if the stator tube is like that down its length making the tube diameter smaller?
It just looks like the cloth bound wiring cluster is "too wide" to go down the tube but maybe with lube and a wire attached to the longest wire it could be pulled thru. Any thoughts?
