AUSMHLY
Now that the Positive Pertonix unit has been installed in my positive BJ8, the car does not start as quickly as with the points. I believe it is installed correctly.
It seems to start between 3-8 turn over's.
Sometimes I hear it start and turn the key back to middle.
Sometimes I do not hear it start, turn the key to middle, then it starts.
With points it used to start 2-3 revolutions, every time.
What's going on?
I was under the impression that installing the Pertonix should make for a more reliable ignition. One less thing to have to tinker with. Plus the car may run better?
It was installed by my mechanic and he checked the timing. I asked him about this starting issue, and he said that's just the way it is. Sometimes I wonder if he is telling it like it is, or mabe just doesn't know.
Looking forward to advise as to what I should check or do.
Cheers, Roger
What's going on?
Cheers, Roger
