But I keep seeing where people are wet sanding after painting. I don't understand that.bugimike said:Kim, wet-sanding is a finishing prep stage to painting. The cardinal rule is that paint does not hide anything. If you have a "wart' it will still be evident even with a coat of paint over it. Paint application is only the final finishing touch of a good paint job. Your primed surface should be perfect before paint is applied! By wet sanding, you get a super-smooth surface on which to apply the paint and let it flow for the "showroom shine". Wet sanding will also allow you to check your bodywork for trueness by observing the reflection or shine on the wet surface. A dimple or a wave is much easier to see on a wet surface than a matte, dry primer surface! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
I had a relative in the SF Bay area whose business was restoring old RR's for some very wealthy people. Brush painting was the only way. Don't know about today's paints, but then, it took months for the paint to cure between coats & sanding. No wonder it took years to restore a car, but his customers would have it no other way.jlaird said:You do know that all cars were painted with a paint brush untill the 30s and even then the expensive ones like RR were brush painted.
If it saves me $2,950:00, so be it.Morris said:I read about 3 pages before I felt like I had had enough for life.
