John Loftus
[ QUOTE ]
When I aggressively step on the gas to speed up, it comes out of OD and will stay out as long as I keeping giving it more gas, speeding up. Once I let up on the gas, it will return into OD.
[/ QUOTE ]
Roger, this is not right.
[ QUOTE ]
If I want out of OD entirely, I simply flick the toggle up and it comes out.
[/ QUOTE ]
In 3rd and 4th, it should only come out of OD if you have enough throttle (at least 20 to 30% depressed) to get the engine revs up. If you click out of OD in an engine brake situation (throttle off) you can shock the gearbox. There is an OD switch (and relay) on the firewall which needs to be operational and adjusted correctly OR you need to learn when to get out of OD so you won't strain the gearbox.
Cheers,
John
[/ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Cheers,
John
