TR2/3/3A Another mystery part
deuce
Hello all .. I had this rod zip tied with the two braces for the crank start guide. I haven't been able to find it in TR3a parts breakdowns. Can anyone give me a pointer. Thanks in advance.
Frank_D
I do not have an image to share, but this fitting is part of the steering column support just under the dash. I will hunt around for an image later in my day.
deuce
Thanks Frank. That's it! I have the radiator stays in place. i also have the crank handle guide braces (two). There is a mounting tab of some sort and a threaded hole in the bottom of the crank guide. Looks like there would be a third brace, though I haven't found it yet. It's only been 6 years since I disassembled it. If so would you have a photo of that so I'll recognize it when I see it. Thanks, George
Frank_D
There is a screw or bolt that threads into that hole you see in the bottom of the crank guide. Check you parts bin for one that might fit. I am in Florida and my car is in Canada so I cannot tell you the thread size for that hole. I also used a star lock washer. Good luck hunting.
charleyf
It is just a 1/4" fine thread.
Charley
D TR2/3/3A Another mystery part(s) Triumph 2
D TR2/3/3A Another mystery part..or two Triumph 14
T TR2/3/3A Another Mystery Part Triumph 8
coldplugs Yet another mystery car Other British Cars 31
Michael Oritt Another mystery photo Austin Healey 8
coldplugs Yet another mystery car photo Other Cars 17
Darwin Spitfire Another mystery to be sloved with my spitfire Triumph 8
Y MGB Time for another puzzle piece.... MG 5
P Another beautiful Sunday Spotted 0
L T-Series Another brake prob. ? MG 12
T I added another TVR to the fleet. TVR 10
AngliaGT ANOTHER TR6,& an MGB Spotted 0
Rut MGB Another sad day! MG 10
T General TR Another trans popping out of 2nd Triumph 14
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
JPSmit you won't likely see another Spridgets 4
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Another brake bleed question....... Triumph 17
Sarastro Another SoCal TR3 Spotted 1
7 Wedge Got another one! Triumph 3
Sarastro TR4/4A Another 50K TR4A Triumph 5
HealeyRick GT6 Another Satisfied Customer Triumph 3
nichola TR6 Another TR6 back on the road Triumph 1
Sherlock Another cruise night, more interesting British iron Spotted 2
D TR2/3/3A Another Carb question. Triumph 22
Healey Nut Another Use for J-B Weld Austin Healey 5
D TR2/3/3A Have exchanged one leak for another. Triumph 10
dbenichou289 TR2/3/3A Another exhausting thread Triumph 10
John Turney Another Article to Criticize Austin Healey 5
tr6nitjulius TR6 TR6 made another list! Triumph 5
Lin Another Trafficator/Control Head Question Austin Healey 10
Rob Glasgow Can I find Another one as Good? Austin Healey 4
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Editor_Reid Bought Another One Austin Healey 14
tr6nitjulius General TR Triumphest 2019 another one bites the dust! Triumph 2
pkmh Yet Another Oil Question! Austin Healey 8
P TR2/3/3A Another Differential Question Triumph 22
Bob Claffie Spotted another AH Spotted 0
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
jackq Another building full of cars available. Other Cars 0
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
Lin Another trafficator issue Austin Healey 8
B Another OD question Austin Healey 32
Elva164 Finally did another onboard video! Racing 4
Sarastro TR4/4A Another milestone: first engine start Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
Y MGB Another question - this time on seatbelts.... MG 2
PC another one bites the dust... Restoration & Tools 0
