Okay, so I got my horn to work -- in a way. I ran a ground from a bolt on the rack to a good ground, and the horn now works when the ring is grounded.
The problem is that my custom steering wheel has an aluminum hub. That hub is touching the ring when the wheel is installed. I looked at my original wheel, and it has a bit of a relief machined into the bottom of the hub -- which my new wheel does not have.
I'm assuming that I can use some sort of nylon or felt washer between the hub and ring to keep the wheel from grounding on the ring. Thoughts?
Hi Guest!
